Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,967
- Location
- Ride
I bought 6 of these to try them out as a possible rack substitute for solo use and/or to fit on my newly painted hard cases sides or lids if the curve matches.
They are Rocket Touring embellishers meant for one to be mounted on the rear fender with adhesive already fitted ready to peel and use. I thought I would get some and try them out and am happy to say they fit the Rocket Roadster rear fender behind the solo rider's seat perfectly.
They are currently highly discounted on World of Triumph UK and the USA online site below
Was: £20.83
Now: £9.32 (US$12.44)
Triumph Chrome Rear Fender Trim Blade
Currently cheap in the US too here
US$15 each now, was $30.
Chrome Fender Trim Blade | A9738113 | Triumph Motorcycles
You could probably get by with 3 or put 2 in the center between stripes if you have them, and one each side on the outside. You could stagger them too or even put two rows for a longer rack area.
You could use spool bolts as tie down points or if you have your easy bracket ones they should do as well with or without the bags attached.
10.5" long and max 1.25" wide, heavy duty chromed steel not plastic of chromed pot metal zinc.
They will stop your bags rubbing the fender paint and look cool.
Triumph Motorcycle Description: RR FENDER EMBELLISHER BLADE CH
Triumph Motorcycle Part Number: A9738113
Will fit the following models: ROCKET TOURER ACCESSORIES 2008
'Huevos!' is just a concept for confused people. Like chickens thinking they have testicles to spare instead of just eggs.
Was: £20.83
