Exhaust shield screw...?
mine didn't as it was the bottom heat shield and it is held in quite well by the bracket thing at the back....just a thought
ill check it, but frankly not sure when i lost it and i did about 100km since then going to and from work, maybe more! Thanks for the heads up tho, nice to learn from other issues. it probably fell off while going too fast
They only fall out because they are not checked for tightness every once in a while check all nuts bolts screws that are accessible and that includes the screws that hold your indicator lens in place.
Or do what some of us do, one by one remove what you can apply thread lock reinstall.
Allthingstriumph.com, triumphestore.com, worldoftriumph.com (the latter in the EU), etc.
But before you buy the screws, buy yourself a bottle of blue loctite and go around the bike and check your screws. Those allen screws tend to vibrate off, I had to secure almost every single one holding my radiator shroud in place for instance with blue loctite.
This is like the third post I have seen on this. Everytime I wash the bike we check for loose items while cleaning. Many of times have fixed a problem before it became a problem. Yes if something works loose and loctite is practical we use it especially on the radiator. Figure when I get my new exhaust will hang on to the screws and probably hook somebody up.
