Is an Eastern Beaver Headlight Relay kit a good idea in a 2011 Touring or was the problem fixed by then? I'm having occasional no response episodes when I push the starter button (it always does start after 2 or 3 attempts).
To fix the starter button problem Spray some "CRC CO2 contact cleaner" in the starter switch and after it has dried (evaporated) squeeze some Dielectric Grease in the switch, this is of course done from inside the housing after taking it off handle bar, as far as the E/Beaver kit I would do just for longer lasting Ign Switch and brighter lights
I always believe you get what you pay for and besides you only use a little so it lasts a long time and there will be other times that you will need it, there may be a cheaper product out there but whether it works as well ??????
