Do 5 3/4" Daymakers fit into stock buckets?
yes
and the light is better than great. several of the guys have them.
Yes they do fit straight in, but I did use longer screws that go through the chrome ring that holds the light in the housing. I think the screws I used were about 7 mm longer than the stock screws.
I managed to reuse the original screws - just a bit of force to push together
Same as Mittzy I used a soft jaw vise grip clamp to squeeze the rims close while using stock screws.
we used the same screws it just took two of us. we did not use the rubber gasket that came with it.
No modifications.
looks good, can't wait to them on my bike.
Another question, if you go to all LED lights, is their still a need to do the eastern beaver bypass kit, or does their low draw offset the need??
