Terminater
.060 Over
- Joined
- Mar 27, 2012
- Messages
- 111
Riding along while coming up to a stop sign bike started shutting down, and then completely died. Speedo/tech start moving all over the place. Pulled to the side of road popped seat checked battery cables, and also check the ground to the engine. Also check power cable to starter, and all seem ok.
Turn the key on, and turned the kill switch on. Hit the start, and it fired up. It had the service engine light on but seem to be running fine. We were like 50 miles from home. So off we went taking the back country roads. Thought if thing went bad on back road we could ditch load it in a truck.
Well got 10 miles from home, and it started popping/dieing again. Pulled to the side of the road. Bike was completely dead. Inspected things again. Thought turn the key back on, and click the kill switch back on to I could try to restart. It restarted again like nothing was wrong. It even cleared the trouble light.
Finally got it home. Put it up on the lift. Hooked the laptop up, and it did not have any fault codes. Also took all battery connection off to inspect. Took the engine ground off, and starter cable off to inspect. All seemed good. But my Acid Reflux disorder was raising hell.
Thoughts are it is the ignition switch, or the kill switch.
Any advice on how to rule this stuff out?
