Changing handlebars (and cables?)
Kim Turner
.040 Over
New Mexico
2007 triumph Rocket III Classic
Have a 2007 Classic with stock handlebars and the slightly higher triumph risers. Anybody out that has tried a harley pull-back type of bar, or any other type of bars they would recommend? Not really looking for ape-hangars or T-bars. Thank you
The bar changes require some adaption. I cannot help re pullbacks as have run 14 and 16" apes and the16s were super comfortableand got rid of the shoulder ache i got on one shoulder. Both had Rivco risers too but I'mtall so one size or style doesn't fit all
What year is your rocket?
What digital gauge is that?
With the introduction of ABS in 2010MY a new system was introduced requiring a matched series ECU .
If you disconnected ABS AND replaced your ECU with a used early series pre July 2009 and earlier ECU .
You MAY then be able to use a Dakota or Koso etc.
Brotha from Down Unda, do you think would work? I need pros and cons so I can weigh it out. I prefer to use the Kosi over analog
From reading threads over the years I assume it can but @barbagris , @warp9.9 or @R-III-R Turbo or @DEcosse could confirm.
You would be giving up ABS though.
I'm afraid I've never fitted an aftermarket gauge to a Rocket, but yes from what i read the old Rockets are much easier to hook up to them. The 2010+ Roadsters have multiple things in them that makes it considerably more difficult.
