Ok . . I have finally made the jump into the new century and have done some tuning on the FBG for the decel pop. I did what Pigger said on another thread and pop is nearly gone . . gonna try another 5% this weekend . . . My dealer was kind enough to let me use his cable and laptop
But my question is this . . What exactly are the L tables and what are the numbers on the left side??
Question 2 . . what exactly are the I 1-4 tables and what do they control?
And yet another . . where do yo correct the speedo?
and last of all what is the square root of 1,200,476?
The L tables are for smaller throttle openings 0 to 15% I believe. The numbers on the left are the load determined by manifold air pressure. The F tables are for larger throttle openings and are indexed by throttle position. From about 10% to 15% the ECU interpolates between the L and F maps.
I tables are for ignition. I 1 is neutral, don't mess with it. I 2 is first gear, I 3 is second gear and I 4 is 3rd - 5th gears. In I 2 and 3 the timing has been retarded somewhat to restrict power. This is more noticeable when you hit "G" to see the graph compared to I 4. If you copy I 4 to the I 2 and I 3 maps you get more power in the low end of 1st and 2nd gears.
Just off of the top of my head without access to Tuneboy it is the options tab then tune constants. The stock speedo is 6% off.
