Brake fluid replacement/flush
imcool
Turbocharged
Rocket 3R 2022
hi,
In next service, there is brake fluid replacement required to be done.
I am worried if I will get soft brake issue afterwards.
Should I go to dealer(400km round trip)
or
should I do at home? I have tuneecu + OBD mx+ as well as dealertool.CO.UK cable
thanks
I have both tools for abs bleeding, I forgot to add in OP. I called triumph dealer in USA ( closest to me) he told me 225 out of door for both brake flush
Edit: found answers to my own questions :thumbsup:
"Both tools" being the Dealer tool and TuneECU? I didn't know TuneECU had that ability.
OK, I see many mentions of it now- I guess so...
Also, just learning that the "Dealer Tool" is not made by Triumph, as one would expect, just the name of the software "tool."
How much was the dealer tool? Found it- about $100 US here... dealertoolcouk.ipage.com
If TuneECU has the ability, I don't see the need to buy this additional "tool."
I've bleed without doing the ABS, but need to do this at some point.
I flushed front and rear last november with Deleartool. I'll find out in end April if all went well!
Kevin, can you please outline all of the brake bleeding steps for with abs? I have searched youtube but no luck with recent/newer bikes abs bleed procedures. :S
When I was looking at buying the "Dealertool," I found this. Maybe helpful....
