welcome from arizona.
some of the new rockets have had a problem like that they seem to go away after a while or they take in to dealer to have them reset.
thanks man, I brought in once and of course they said they did all this stuff and what happens as im driving home, the same **** thing. I don't want to bring it back because they take so long with it.
there are threads about this (u can use the search feature at the top right of the page) or more than likely some of the pros will explain it.
Welcome from NJ, enjoy your new ride! What # you have! Sounds like your TPS ( throttle position sensor) had a similar prob when mine was new. might need adjustment? Good luck!
Welcome from Mississippi! Where in LA. Most of the threads regarding that issue seem to conclude once they loosen up after the first service, that problem goes away?
G'day and welcome. It will loosen up a bit and the problem should go away after the first service when they take the dynosaur oil out and put synthetic oil in. They should also check the TPS when they do the service, although that doesn't mean they will. However, it is easy to check and set if needed at home with TuneECU.
