warp9.9
Pocałuj mnie w dupę
Bummer, the torque on them little buggers is light are you using a inch pound/NM torque wrench?
Once you take it off you caqn drill the bolt out from the back side. The bolts miss going completely thru thr hub by .625" so there will be plenty of pilot hole for a good machine shop to drill it out for you if your not set up for it. I would use 45 mm long bolts to replace them. Or that is did what I did with mine, I use grade 8 equivalent. I believe mine let loose due to the short bolts or at least the spring towers snapped below the bolts in the area that was hollow.
here you can see how far the bolts go in. You can see they stop before the filet radius on the spring tower.
I
below is a bolt placed up to the vernier that is set to the length of thread in the spring tower.
I ordered my bolts from Fastenall, and I knocked the washers off the old bolts so I could use them. The washers on the bolts are larger diameter then I could find for sale.
Here s a look see at my damage so you won't feel so bad about yours.
wasted the blower cover also which was a good 1200 plus shipping from the UK
Four of the five spring towers broke up and the fitfh one is all bent up. Don't read to much into my breakage as I am running a wee bit more HP then stock.
I
