That was my plan from your previous post on the subject pigr, It made perfect sense. I don't have any trouble with it until I try to shift fast under hard acceleration using the clutch. If I just burp shift without the clutch it works fine, but if I use the clutch it will slip for a short time in each gear. So I seldom use the clutch for anything other than taking off anymore.
Your solution is all it needs until you go nuts with the mods and HP starts getting up there. You haven't had any trouble with the head snapping off the new part with the stiffer springs have you? That seems like it would be the new weak point with Barnett springs.
