theharleydr
Voltage regulator tested bad, replaced, still no charge.
New full battery,
the service manual tells how to check ACV output which proved to be in spec, BUT.., a grounded stator will show good ACV output until loaded. As soon as you are connected and running you are loading the stator. Thus dim headlights and charging voltage lower than battery resting voltage.
Turns out all three legs show continuity to ground.
Any short cuts to pulling the motor?
AGAIN!
Did the trans update kit at 20k, new clutch at 30k now new regulator and stator at 33k.
Oh yea fuel pressure regulator at 6k.
my rocket loves me.
New full battery,
AGAIN!
my rocket loves me.
