Rocket Scientist
Grand Exulted Poobah
- Joined
- Sep 27, 2009
- Messages
- 6,851
- Location
- Spring Lake, Michigan
- Ride
- Black 05' Rocket III standard
If you don't have me blocked you may know that I too am experiencing guage (clocks for you Brits ;-) problems. Started with odometer becoming dim, than trip meter re-setting to zero at start up. Went to look into it yesterday. Turned on key, no sweep, no idiot lights, no odometer. Lifted tank. Traced guage wires to large plug. Pulled plug apart. Not good, terminals all green. Cleaned up as best I could. Still no good. Did find I could partially un-plug and jiggle it and the tach would sweep and the idiot lights would come sometimes if I held it just right. Today cut plug out and soldered wires direct. STILL no sweep, no idiot lights, no odometer. However, I found if I start the engine. All the idiot lights come on, and only the tach sweeps, then all the idiots lights go off except neutral and low fuel (tank is still raised). Odometer looks normal again. Any ideas ? Is any of the can-bus stuff in the part of the ECU program we load with tuneboy / tuneecu ? Would it help to try reloading the tune ? This here is what chu' call yer stumper !
