Fitted Ramair and cat delete single open muffler. The is a sensor in the Ramair intake I noticed there is one in the old airbox as well . what if anything should be done with this sensor. Cheers
The map sensor was attached to the plenum via 1 bolt it was mounted a few inches behind the AIT on the plenum. It also has a lage vacuum line. The sensor under the seat in the air box where the filter goes senses atmospheric pressure changes ie. altitude, it is the barometric pressure sensor. It can stay there . A few might have moved it so it wasn't sitting in a stagnant box of hot air. A better choice is to plumb fesh air into the box cooling the box that your sitting on.
