Air cleaner mod???
Interesting.Will it fit under the bearclaw or is that the reason for the cut in the bearclaw?
From all reports I have read on here the Ramair filter flows Better than the K&N 2780 small filters which fit under the bear claw, only the larger filters flow better than the Ramair but you will need to modify the cover.
I thought about it but went with the larger K&N filter for better air flow. Bulls is right the stock air ducting is restrictive
Scott,
When is the Falcon hitting the roadways again???
The 2780 filters are the small K&Ns
