Air Bag Suspension Kit
Max length 12" - Very much aimed at the "Gangsta" height adjusting crowd who are not so "corner" orientated.
I'd fit Fournales if you want air springs. They're a bit over length and this is a plus as it makes the R3 a wee bit nimbler. I'm really pleased with mine.
to bad they are short as it would be nice to change on the fly plus you could use the compressor to run a air-shifter when nt adjusting the shocks.
I am planning on mounting a set of Goldwing air shocks and the compressor to go with them. Figure i can put the compressor where the air filter goes under the seat. Just need to do the triple K&N's. Either that or Progressive Suspensions air shocks. Their site shows rockets using the same part numbers as Goldwings and Valkyries so I should be good. Just need money to get it all done.
