I installed the maddogs two years ago the 12min tune does the job fine, if you go with the cat bypass like I now have you will have to try a few tunes not the 12min tune as the popping in decel is terrible, i ended up going with tuneboy. 8)
I ran just the Mad Dogs for a good while with only the 12min tune. When I put the cat bypass on I again used the 12min tune and it ran fine. The after firing on decel was terrible on mine too. I put the PCIII on it (tuneboy wasn't available then) and it cleared it up. I think you'll be fine the way you are. You will eventually want more though
