Woolich Racing one of Pros in tuning world has released product for Rocket 2.5
100% with you! My KTM SuperDuke R 1290 has spoiled me... But one has to experience this before you can understand it!
I have no statistical results- that would require a dyno and from my perspective- why? Those who know how to make sense of the fuel tables will surely chime in with data based evidence. I wonder if you successfully loaded that map.
Not my first map, not my first bike mapped, not my first time with TuneEcu. The map will not work without error codes if not succesfully loaded. I am very willing to share my map and very willing to learn. Regards.
I'm no expert on TuneECU and had trouble loading the Penner tune at first, so you could no doubt teach me there. Sounds like you got it and are simply unimpressed. For me it wasn't like when I rebuilt my Roadster with a Lush kit, but a no doubt about it change in performance in throttle response and grunt, but as they say, "your mileage may vary."
This is regarding Penner's Tune
From @Neville Lush (see post #639)
Yep! Now again do the same math and see the power to weight ratio... and you still have a problem... I agree the map improved the overall performance as shown on the data sheet but to really make a noticeable difference you need much more hp to curb the 320kg weight of the Rocket! That is precisely why a super charger was developed for the Rocket. The maps, exhausts, etc. could only do so much and no more - the bike is heavy! So here is an example of the power to weight taken from the data in the Dyno graph you supplied: Before the map = 136hp (Power to weight = 136/320 = 0,425). After the map = 172hp (Power to weight = 172/320 = 0,537). To put this in perspective my KTM SDR 1290R weighs 195kg and delivers 188hp... Power to weight is 0,964. The magical number is 1:1. Weight is a problem!! Regards!
With my body weight + gear, Werkes exhaust replacing the stock exhaust, and the Penner tune, the Rocket 3 has the same power:weight ratio as my Tiger 1200 GT Pro without bags. Slightly better, in fact. It's no slouch.
Maps can only do so much- yes, of course.
No one is expecting super charger results, or even anywhere close, from a tune. What it does is successfully de-restrict all the already available power built-in to the Rocket
I found with the Viking exhaust I lost 25lbs off of the bike and when we dyno tuned the bike we had to take about 10% of fuel out of the top end of the Penner tune. You can't directly compare dynos but we wound up at the rear wheel 172hp and 144ft-lbs of torque. Though based on the top speed they said we had I think there was some slippage going on.
