Widow maker journey to the 200hp club
Discussion in 'Rocket III Touring Forum' started by Kevin frazier, Aug 12, 2019.
  1. Jvheli
    Jvheli Turbocharged
    Country:
    United States
    658
    Featured Threads:
    11
    1,107
    103
    Milwaukee, Wisconsin
    Ride:
    2016 Rocket Roadster
    If your doing the cams yourself (the most challenging part). The rest is nuts and bolts man. Plus, there’s great help here if you have a question.
    1olbull, Joesmoe and Kevin frazier like this.
  2. Kevin frazier
    Kevin frazier Widow maker Nashvegas
    Country:
    United States
    845
    Featured Threads:
    3
    1,035
    203
    Nashville
    Ride:
    2008 Triumph rocket 3 touring
    24A9E7EF-3D48-43A0-B59B-5CC1FCC01CB9.png 8B7E6EA0-D2D8-4F19-B167-29ACC4D41F96.png 60D70FF6-482E-46C8-87D6-5F89B7404D52.png 60D70FF6-482E-46C8-87D6-5F89B7404D52.png 60D70FF6-482E-46C8-87D6-5F89B7404D52.png
    So said the 30yr vet a&p, but that did make me stand up and go yeah, yeah I got this lol, cams most challenging, thinking of you and speedy speak of torque types and bolt stretch and you nervous when starting in driveway turns stomach a bit, because I don’t even come close to youlls thought process
    Jvheli and Steel like this.
  3. Jvheli
    Jvheli Turbocharged
    Country:
    United States
    658
    Featured Threads:
    11
    1,107
    103
    Ride:
    Lol. I was not aware of a process as it pertains to thought......Il try that next time!:D
    The only REAL skill needed is patience, and attention to detail. The rest, nuts and bolts.
    Joesmoe and Claviger like this.
  4. Old N' Grumpy
    Old N' Grumpy Living Legend
    Country:
    United States
    3,267
    Featured Threads:
    10
    9,714
    823
    Ft.Lauderdale, Florida
    Ride:
    2014 Triumph R3R & 2005 Harley FatBoy
    How come everyone's using Neville it seems and not Carpenter Racing??? Better stuff I presume???
    Joesmoe likes this.
  5. Jvheli
    Jvheli Turbocharged
    Country:
    United States
    658
    Featured Threads:
    11
    1,107
    103
    Ride:
    I wouldn’t say better...Carpenter has Megacycle do the cams (good reputation), CP for the pistons (good reputation) and I believe Suzuki parts in the valve train and clutch. What I like about Lush Racing is he contributes here, seems to really get that we don’t all want the same thing and offers choices.
    Bob Carpenter is a genuine dude, easy to talk to and very knowledgeable.
    Steel, Kevin frazier, Tripps and 2 others like this.
  6. Dr.D
    Dr.D Octane Boost
    Country:
    United States
    1,550
    Featured Threads:
    13
    2,764
    323
    Tazewell TN
    Ride:
    Indians and the R3 2014 Roadster
    My mechanic spoke highly of Lush not as much Carpenter.:rolleyes:
    Tripps likes this.
  7. Joesmoe
    Joesmoe IMOKUR2 Staff Member
    Country:
    United States
    3,842
    Featured Threads:
    42
    Media:
    5
    4,877
    823
    Fairfax, Virginia
    Ride:
    Triumph: 2014 Rocket III Touring
    Carpenter has one big advantage over Nev, *if* you're in the US, and *if* you have the money: he offers ride-in-ride out service on a product he sells.
    If you live in his part of Australia, or, you have a tool set and mindset to DIY, Nev offers much better cost effectiveness in dollar/hp made, especially when combined with good exhaust and intake (as pointed out by @Steel ). And while Nev would like to sell you his cams and tensioner, he will quietly suggest one can go a long way for performance on a 2.3L motor with just the exhaust and intake and legitimate ECU remap.
  8. Claviger
    Claviger Meh
    5,816
    Featured Threads:
    137
    Media:
    69
    8,060
    823
    Olympia Washington
    Ride:
    '14 R3R, '02 Daytona 955i
    Without opening a can of worms about the differences between the two setups.
    Carpenter offers the three setups, but will/can do other things upon request.
    For example, I put a 265 head, milled .1" on a stock bottom end. It made 190 with CES, probably would've cleared 200-205 with the brute/sidewinder. Cams were too big for the compression ratio. When the pistons were done it was a 41hp jump because the cams were now a little too small. Then opening the pipes up gained another 22hp because now the engine could actually use the extra exhaust flow capacity to its fullest.
    Neville has a large number of cams to chose from and can/will match the right cam, cam timing, and compression ratio together so you have a strong but also healthy combination.
    Remember the whole package is a system, from air filter to exhaust tip. What you do on each end or anywhere in between either synchronizes with the rest of that system in harmony or it doesn't. When it doesn't you won't see the expected gains, when it does, you'll get at least the expected amount. This definitely includes cam, cam timing, and compression.
    Gerald, Dr.D, Starmanut and 5 others like this.
  9. Claviger
    Claviger Meh
    5,816
    Featured Threads:
    137
    Media:
    69
    8,060
    823
    Olympia Washington
    Ride:
    If you were to do cams first, sized for a higher comp engine, they'll be too large, so you'll have a lazy throttle response, lose a good amount of torque below 3500 and won't see the big gains up top you would expect.
    Best solution to avoid doing things twice is pistons, and cams, at the same time.
    Gerald, Dr.D, Kevin frazier and 2 others like this.
  10. Jvheli
    Jvheli Turbocharged
    Country:
    United States
    658
    Featured Threads:
    11
    1,107
    103
    Ride:
    Rob said it better that I did, but it’s what I was getting at.
    Steel, Claviger and Joesmoe like this.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
