whining noise
kenne
Turbocharged
Gold Coast, Australia
05 Rocket iii Rat
G'day All
Riding to working yesterday along the hwy I noticed a whining noise, seems to be when under throttle Can't tell if it's engine or drive train. Any Ideas ???
cheers
Is it there when in neutral?
Does the tone/frequency change with rpm or speed?
Does it stop with clutch lever pulled or change with different gears?
Is it there when you pull the clutch and close throttle while coasting at speed?
It changes with RPM, and goes when I throttle off, checked that as I thought it might be wheel bearing. definitely when the engine is under load in the 4th and 5th can't really hear it in the other gears.
Will do clutch check on the way home.
Yes, do not allow her to ride pillion again
hehe Nah i brought her a Bonnie of her own so i don't have too, and no bluetooth in my helmet
G'day All
cheers
Did you happen to ride by a visiting US Democrat?
