Weird noise coming from the front
Pump_Guy
Aurora, Colorado
2020 Rocket 3 R. Phantom Black
Hi guys
It is an odd noise coming From the front when starting from a total stop. It is something like is dragging. I have notice that if I increase the rpm’s before start up the noise disappears. This is just happens after a complete stop. After the bike is running normally the noise is no melote there. Weird
Have you experienced something like this?
Thanks!
Maybe the front brake pads are hanging up a bit. Crud builds up on the pistons in the calipers! You can clean the crud with brake cleaner and a toothbrush, but you will have to remove the calipers!
Try looking at the front brake discs first, if you find a black line on them, it can be something stuck under the brake pad, happened to me not that long ago. Noticed weird sound while pushing the bike in the garage.
