My bike is an 08 and the factory coating was done so I had little choice but to stripem and shinem, gonna be heck now though to keep clean, you may be ok just to aluminum polish and buff maybe some 0000 steel wool and the simple green if there not bad like mine were, just gettem shiny it’s a rocket
I have never found a simple solution. The best way is to stay on top of the situation and not let them get to bad. Some #0000 steel wool and aluminum polish has fixed a bad area or two. I only had one bad spot that looked like they had washed the bike and left water set on the bottom of the rim. The use of a proper aluminum wheel cleaner helps as well but don't let it set to long on the rim before rinsing. Do a test spot as well.
