raytracer .040 Over Joined Apr 4, 2007 Messages 60 May 7, 2007 #1 20151 20145 Rocket III with aftermarket exhaust (No catalyst) 20149 20145 Rocket III with aftermarket exhaust with cat box removed
RiderRocketman Supercharged Joined Sep 13, 2005 Messages 430 Location Twin Cities, MN USA May 7, 2007 #2 Do believe the first is for an empty catbox only found on pre-2006 models from the U.S. excluding California. The other tune is for the catbypass pipe or what Triumph calls the exhaust upgrade kit or for any aftermarket pipes that bypass the catbox.
humble .040 Over Joined Dec 3, 2005 Messages 66 Location TampaBay May 7, 2007 #3 RiderRocketman said: Do believe the first is for an empty catbox only found on pre-2006 models from the U.S. excluding California. The other tune is for the catbypass pipe or what Triumph calls the exhaust upgrade kit or for any aftermarket pipes that bypass the catbox. Click to expand... You are correct sir!!! :wink:
