Flip
Once again someones pumping sunshine up your ass.A stock SRT4 will not out run a rocket..Estimated Price: $19,995
Chassis Code: PLDS41
Engine
Engine Code: A853
Type: Inline four, turbocharged
and intercooled, iron block
and aluminum head
Valvetrain: DOHC, four valves per cylinder
Displacement: 2429cc
Bore & Stroke: 87.5 mm x 101.0 mm
Compression Ratio: 8.1:1
Manufacturer's
Horsepower : 215 hp @ 5400 rpm
Horsepower as
Measured at the Wheels: 223 hp @ 5600 rpm
Manufacturer's
Claimed Torque: 245 lb-ft @ 2000 rpm
Torque as Measured : 250 lb-ft @ 3100 rpm
Redline: 6000 rpm
Drivetrain
Layout: Transverse front-engine,
front-wheel drive
Transmission: Five-speed manual
Gear Ratios
1: 3.647:1
2: 2.045:1
3: 1.367:1
4: 0.947:1
5: 0.756:1
Final drive: 3.526:1
Differential: Open
Exterior dimensions
Curb Weight: 2,870 lbs.
Weight Distribution F/R : 64/36
Overall Length: 175.7 in.
Wheelbase: 105.0 in.
Overall Width: 67.4 in.
Track F/R: 57.6 in./57.7 in.
Height: 56.5 in.
Suspension
Front: MacPherson struts,
anti-roll bar
Rear: Struts with two lateral links
and one trailing link,
anti-roll bar
Brakes
Front: 11.0-in. vented discs,
single-piston sliding caliper
Rear: 10.6-in solid discs,
Wheels and Tires
Wheels: 17x6-in. aluminum,
45mm offset
Tires: 205/50ZR-17
Michelin Pilot Sport
Performance
Acceleration
0-30 mph: 2.5 sec.
0-60 mph: 5.8 sec.
30-50 mph: 2.0 sec.
50-70 mph: 3.0 sec.
Quarter Mile : 14.2 sec. @ 99.5 mph
Handling
Lateral Grip (200-ft. skidpad): 0.85g
Slalom (700-ft. six cone): 69.0 mph
Braking
60-0 Stopping Distance:
My brother in law has one and I out run him over 6 car lengths in a quarter. Yes Its one of the fastest little cars around but not going to beat the rocket..23.000 CCs against 24.000 CCs but the neon weights almost 3.000 LBs. and the turbo cant make up for that..You must have been talking about a modified version.. Jack
Engine
Engine Code: A853
and aluminum head
Manufacturer's
Horsepower as
Manufacturer's
Redline: 6000 rpm
Drivetrain
front-wheel drive
Gear Ratios
1: 3.647:1
2: 2.045:1
3: 1.367:1
4: 0.947:1
5: 0.756:1
Differential: Open
Exterior dimensions
Height: 56.5 in.
Suspension
anti-roll bar
anti-roll bar
Brakes
Wheels and Tires
45mm offset
Tires: 205/50ZR-17
Performance
Acceleration
0-30 mph: 2.5 sec.
0-60 mph: 5.8 sec.
30-50 mph: 2.0 sec.
50-70 mph: 3.0 sec.
Handling
Braking
