If you are planning to go carpenter then you get most out of that package by using their exhaust "the Brutes" it is designed for the high end power the carp package is designed for if you were going for a lush engine set up the CES would serve you better as the lush engine set up is designed to produce the power in the more commonly used areas below 6800rpm and so Is the CES headers
