rusty
Turbocharged
HeR3tic, re-read my post about the centerstand if you would. When the Rocket is on the centerstand, the rear tire is "just off the ground" and can be turned by hand. My statement was: "I can lift the front wheel off the ground with about 20 to 30 lbs of lift" by hand. Or, I could get a piece of 2 by, cut to the proper length and "prop" the front of the bike up leaving the front tire off the ground. One other fact, if I throw a piece of 1/4" to 1/2" plywood on the ground where the centerstand is going to be, I get an extra lift of the rear wheel, which translates to more lift of the front when "Rock-et-ed" back on the rear tire.
One correction to your statement. Even if the stand was turned 180, wouldn't the "same event occure (rear tire lift) due to the lifting "points" being the exact same as the other way? Possibly? Maybe? I think so! Just had to throw that at ya buddy.
See ya. And if you ever feel that you might want to "spring" for the flat parts of the centerstand (I get the plate pieces for you and you supply the round tubing & welding), let me know & we'll work on it together.
