markc said:
dw raider
I just had mine in the shop for the same issue. It sounds and feels like a low rumble, not a fast vibration. My dealer said that they couldn't find anything wrong. Mine started after they replaced the tds unit last august.
It hasn't got any worse but it is still there. I also have an intermitent vibration in 5th gear. so bad some times i can feel it in the footboards. My left mirror gets fuzzy while my right one is clear. I'm thinking the throw-out bearing and not the tranny. My bike is still under warranty so at least this problem is documented.
MarkC
the throw-out bearing is located at the front of the cluch
and there for pull the cluch to release the tension from de spring load
If you press the lever to remove the slack you should stop earing the noise and vibration
The worst thing it could happend is you won't be able to use your clutch anymore
you gone a have to run it without using the cluch to get to the dealer
and keep a good distance in front of you to get there
bike car truck are hall the same
For the vibration in 5th gear ««when decell ??»»
mind started out at 3700 rpm and got worst and worst until I could hear and feel the grinding
I had no vibration and noise when twisting the trotle (up in rev's)
But vibration when decel
It was the Torsional Damper Bearings
that was sarting to go bizurk
http://www.r3owners.com/viewtopic.php?p ... ht=#182063
and i hope it's not that Mark C
