John Miller
I have had this issue for several months, thinking that it was clutch basket bearings or wear that was causing a severe vibration (like out of balance or run out) but only when under severe load like WOT from 3,000 RPM upwards.
I have been really concerned thinking I was going to start pulling her down starting with the clutch.
Whilst I bought the bike from an aircraft mechanic who had fitted the crash bars all seemed to be professionally done with appropriate hardware and self locking nuts I never thought I needed to double check bolt torque etc.
Was surprised to find the front engine mounting bolt was at least 11/2 turns from tight.
Now I believe I have found the issue - nothing at all to do with the engine vibration or clutch basket wear - just a loose front engine mount bolt causing the severe vibration under heavy load.
I will source a new bolt to replace the original - assume it will be over stressed after the hammering it's been getting.
Moral of the story is take noting for granted, check all the obvious things first.
