kremmen
I have no power in my garage and no way of running a lead thru my estate.
So I have purchased a ring power pack so that I can jump start my bike if left too long over winter
This works fine but I am planning on popping out during half term and I though if I connect to my optimate the battery might be in a better condition.
I have previously drained a powerpack by trying this overnight and wonder if anyone can work out a period of time that I might be able to advise me using the tech info copied here
12v, 40ah professional PowerPack with 300w inverter, 40ah lead acid battery for professional use jump starting, 300w inverter provides 240v AC mains power, extra long detachable cables, 12v DC auxiliary power outlet, integral worklamp, polarity protection
Battery Size 40ah
Nominal Voltage 12
Peak (amps) 800
Cold Cranking Amps (CCA) 400
or even here.... http://www.ringautomotive.co.uk/product ... ?prod=1592
Other wise I suppose I could take it for a long ride ( not sure how good batttery will be after 4 years of this misuse)
Thanks
Paul
Battery Size 40ah
Nominal Voltage 12
Peak (amps) 800
Thanks
Paul
