BuffaloR3
.060 Over
Fixed: URGENT broken down on the road
On a road trip and broken down. Need to get running.
The story so far: Stopped to look up directions after a construction reroute. Everything was running fine, hot day (I'm in SE Florida just outside Ft Lauderdale). Went to start back up and nothing, no instrument sweep, nothing. I jiggled the key a few times and had a momentary sign of life a couple of times, the odometer would start to light up and go dead, only a split second and only once every ten tries or so. Putting ignition in park gives me headlights, in run position no lights. I swapped around the relays and fuses, no change. Jumpered the kill switch and no change. Pulled the battery and walked it over to Pep Boys (at least I broke down in a commercial area) and tested good. I rewired out the power commander and no change. Reseated ignition plug and nothing.
I'm thinking it's the ignition switch. I did the relocation kit so it's sitting near the motor, might have overheated it. Wiring inside switch doesn't looked toasted but the switch internals might be. I'm not sure what else to look for. Local dealer is closed today but there's another one about an hour away. I can rent a car to grab a new switch if that's what's wrong (providing they have one). Is there any way to test it roadside? If its not the switch then I may just tow the bike and wait until they open. Unless anyone here has some other thoughts. (anyone know how to Hotwire one of these? Not exactly a proper test but should work. I read a couple years ago one could jumper something in the fuse box to bypass the ignition switch).
Bike is a 2006 standard.
Thanks in advance for any help you can provide.
