TuneECU Guide (when ok to start engine)
wildman
Greenville, SC.
Help, the tuneECU user's guide says to start with key on - kill switch on - engine off. However, it does not state when it is safe to start the engine, when performing the DIAGNOSTIC and TEST functions.
I know if you happen to start a car while DTC's are being read you can cause major problems.
basicly, once you have a green light flashing in the lower right corner you are safe to start the bike.
Tune ecu
Just make sure your in the diagnostics menu when u reset your tps after you load your tune other wise you will be waiting all day for the green light to come on for the tps after reseting it if your on the tests screen :rolleyes:
Regards Mitch
:confused:
I have at many bikes with Keihin ECU, the TPS reset performed and always from the map editor window. I never had a problem. The green TPS-light always came.
BR, Tom
Regards Mitch
:confused:
BR, Tom
I had it on the test menu one time and nothing happened but it was fine on diagnostics but i must admit i never tried it on the map edit window.
thanks for the info Tom at least i know it will work on that menu also
Regards Mitch
Regards Mitch
worked on all 3 for me.
