Never heard of them personally.......
I rekon its best to fit a good exhaust as well as the air filter and get that thing Dyno'd.
Worth every cent. 40hp gain, that's all I have done to date - soon to change that tho.
Ok - Are they foam or paper?
If foam, might be very similar to the Uni Filters.
Don't forget if you strip out your air box plumbing you will need a small filter for your crank case also a filter for the sensor is fitted in the plenum.
That's what I had on mine when I first removed the air box. They are foam with an internal spring. It come with Tuneboy, yes, they are the unifilters. Mine were red so it went faster haha. I already had the Staintune exhaust with crossover, had a dyno done before air box removal and was 126hp. Put on the unifilters and went up to 137hp, then 142hp with the tune. Changed to k&n 2780 later and now Ramair. All fit under bear claw but I did cut mine.
