Tuneboy Tune Library
Status
Not open for further replies.
Pig9r
Kansas City, MO USA
This thread is for archiving Tuneboy tunes that have been developed for a specific application and are dyno proven. It seems they have gotten lost on other threads so I will keep this thread locked to reduce the clutter. If you have a tune that meets this criteria and don't mind sharing it with others send me a pm and I'll post it.
EDIT: Pig9r has left the building. PM Joesmoe for any of the above. [20170415]
2006 Rocket III Classic
Maddog Exhaust (has also been used with TORs)
Cat Bypass
Triple K&Ns
The ignition timing is from 20050_3 tune on the Tuneboy site.
Speedo corrected
O2 sensor disabled
Fuel mapping done with a PCIII. The PCIII map was then imported into Tunedit.
  • Pig9rDynoTune.dat
2005 Rocket III
Staintune exhaust
Staintune cat bypass
K&N drop in
Ignition full power
Speedo corrected
Tuning done by Wayne at Tuneboy.
The blue line is this tune.
  • 20050StainTune.dat
2005 Rocket III
Triumph TORs
Triumph Cat Bypass
Triple Uni-Filters
Full power ignition, however the ignition was retarded somewhat in the higher RPM range which resulted in higher power. This ignition mapping was used in my dyno tune with Maddogs.
  • 20050DynoFinalMap_WithPods_And_IgnRetard.dat
2005 Rocket III
Triumph TOR's
K&N underseat filter
Full power ignition
Dyno results reported by Wayne at Tuneboy 147 hp and 157 ftlb.
  • 20050DynoFinalMap_TOR_CatBypass.dat
2005 Rocket III
Jardines
Triple Uni-filters
Ignition full power
*It should be noted that this tune on the Tuneboy site does not have the ignition maps from 4th and 5th gears copied into 1st through 3rd gears. I have fixed that issue with this tune.
Dyno tuned by Wayne with Tuneboy
  • 20145TuneJardinesFixed.dat
2007 Rocket III
Triumph TORs
Triumph Cat Bypass
Triple K&Ns
20222 base tune
Speedo corrected 6%
Rev limit increased to 6700RPM
Speed limiter moved up to 250kph
Ignition from the 20050_3 tune
PCIII O2 bypass installed
Dyno with PCIII, map then imported into tunedit
Tune compliments of MJBell
  • MJBELL.dat
2008 Rocket III Touring
Suitable for both Triumph TORs and D&D pipes
Suitable for both triple unifilters and triple K&Ns
138hp / 150 ftlbs
Compliments of GPMAZ
Link Removed
2006? Rocket III
Triple K&Ns
Predator Pipes with 12 discs and closed end caps
This tune was developed on the dyno by Goodfellow with better mileage and quieter exhaust in mind.
The results are a broader power band than the Predator performance tunes.
140 hp / 141 lbft
The speedo is corrected for a 205/55-16 car tire.
  • goodfellowdynotune.dat
Status
