Macrider,
If you have the Jardines on you can use the tune which is specially produced for the Jardines.It is also on Tom site.
Do you have it on?
Below on youtube you can see why you need use of the Parachute.......
It is limited at 225 km per hour but you can hange that with tuneecu.
The tune is called:
20258Jardines_exhaust_DB_KillersMap.hex
I attached the figures as well.
Then you should have no popping anymore.
I have the D&D underneath because we found to Jardines a little to loud.
Also got it dyno tuned with the D&D , the tune is also on Tom's site:
http://www.tomhamburg.net/Custom_Tune_list.html
Good Luck and enjoy.
Ballyono, with tune 20258 must I physically remove the secondaries or will the map in tune ecu give me a box to check that will keep secondaries open 100% ? Thanks.
Hans
