Trying to fit a Carpenter exhaust and.....
cskals
.060 Over
Fyn, Denmark
R3 standard 2005
Hi all.
I'm trying to fit a Carpenter exhaust and all is good, but the bit on the picture can't be installed at the same time, or can it, and I'm just being a knucklehead?
Hi all.
I had the same problem when fitting my Reband system ....I managed to fit the cover first apart from the lower screw ....it was an arse ache job
not sure if the ssue was fixed with either Exhaust system made by Reband and Carpenter but on the early versions you had to cut the corner off the cover
Thanks for the quick response guys.
Apparently this is one of the first systems and I have to cut the corner of the cover.
