Transmission issue
Can you show me a photo of the later one Scot please ?
Yes my Friend old first
The clutch system has all stock components and made sure I installed the plates back same orientation as I had taken them out.The plates were oiled and springs torqued to 10nm .
After installation of pressure plate had checked lifter piece action but I couldn't move the pressure plate back.I had assumed the plates will losen up after rotation and did't want to damage the lifeter piece button.
Is it typically possible to varify clutch action by pulling lifter piece before bolting on tbe clutch engine cover.
I was planning to change engine oil & fiter after few mintues of running engine .Also had ordered a spare clutch cover gasket just in case,looks like will end up using it now.
I took good advice and did some checks before taking clutch over OFF. Not sure what it was hydrostatic tension or oil temperature it was weird after I had engine running for couple of minutes, with multiple starts & stops. CLUTCH WORKS NOW!!!
Took bike for a spin around the block , shifted through gears but engine was operating rough with the P1105 error. Now digging up in the forum realized I have forgotten to connect MAP sensor tubing to throttle body .Think once I fix this I should have motorcycle back on road.
Scott thanks again for all the input and lending me the Cam timing tool.
The only part I need to replace is driveshaft which is badly worn-out .I had purchased 2 driveshaft's on Ebay both listing mentioned 05'onwards classic model's driveshaft but both these are slightly larger diameter spline at the bevel box end. Was the 05 model driveshaft different than later years ,Looking up on Bike Bandit 05' part number is T1270500 and 06' part number is T1270600?
It is late now, but typically the cam timing "dot" is stamped on the rear of the cam chain lower gear, where one cannot see it...........
Used the timing marks on crankshaft gear as Scott had mentioned but didn't notice a dot mark on cam lower chain sprocket gear 20170313_201321.jpg .
Ok so the two bearings
Bearing Torsional Damper # T1270805 which is a JESA W2 6305 RS single side seal 25 mm x 62 mm x 17. mm (made in United Kingdom) Seal is non metal
the rear bearing # T3801135 which is a KOYO 6009 RS double sided seals. 45mm x 75 mm x 16mm (made in Japan) Seal is non metal.
The seal # T3600068 made in the UK no name only numbers are 3600068 same as the part number it is a Oil seal 40 MM x 62 mm x 6 mm clockwise rotation.
Hope this helps. remember when you take yours apart the front one is most likely in backwards. Of course with all the metal in the sump you might not be able to tell. So when you install the front bearing the seal goes toward the rear of the bike which is towards the cover. The front bearing gets its oil from the passage that feeds the transmission shaft end bearing hence the seal on one side only. The rear bearing is now grease packed and double sealed where the original was single sealed and oiled by osmosis or shear luck of migration.
A thread mine I know, but I found one for sale NOS with good photos. @warp9.9 can confirm if the bearings are correctly installed. I have bought a few things from this seller and great service and if you make an offer she is likely to accept. To get a starting point for an offer start watching it and you will likely receive an eBay 10% discount offer or so within a week or so.
Price: US $350.00
Approximately AU $538.50
Triumph Rocket III, 2006-18, OEM NOS torsional damper assembly kit, T3990194 | eBay
Triumph Rocket III, 2006-18, NOS OEM torsional damper assembly kit, T3990194 / T3600068
New Old Stock. Excellent unused condition, zero miles.
You are bidding on the items in the photos only, what you see is what you get, no more, no less, so please carefully review all photos before purchasing.
Buyer is responsible for ensuring this is the right part for their bike, so please do your research and ask questions. Returns are welcome, but return shipping is to be paid for by buyer. No international returns, period.
Price: US $350.00
I can see the bearings are in correctly. Can't speculat as to why they went thru the hassle of removing it from the cover? Also from what I can see of the helical gear if this is the orignal bearings they were running concentric.
IF it is New Old Stock as claimed why would it come already pressed in to the cover which appears to be part of a different parts group? (Seller Notes: “New Old Stock. Excellent unused condition, zero miles.”)
This part number T3990194 is for the Black Case Cover version of the 3 listed according to my Aussie dealer Triumph parts fiche so maybe it came with the black cover which is missing?
> Eng No 336042 - Blk Cvrs; See Technical News 114
There are 3 covers listed with different part numbers and VIN or engine numbers
17T1260441T3 CVRO/P SHAFTPAINTEx1172.90> Eng No 242554
17T1260442T3 COVER OUTPUT SHAFTx1172.90Roadster Only
17T1260442T3 COVER OUTPUT SHAFTx1172.90Eng No 242555 > 574812
RefPart NumberDescription# On Img# Cart$ EachNotes
1T3990194T3 KIT TORSIONAL DAMPEx1874.00> Eng No 336042 - Blk Cvrs; See Technical News 114
1T3990195T3 KIT TORSIONAL DAMPEx1874.00> Eng No 336042 - Slv Cvrs; See Technical News 114
1T1270800**Dead ->REFALEXx11008.40Eng No 336043 >; See Technical News 114
2T1270870T3 CIRCLIPx15.60
3T1270865T3 CAP COLLETx15.40
4T1270860T3 TORSIONAL DAMPER COLx29.50> Eng No 449436
4T1270898T3 COLLETSx29.50Eng No 449437 >
5T3990192T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Silver Covers; See Technical News 114
5T3990193T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Black Covers; See Technical News 114
5T3990191T3 KIT TORSIONAL DAMPEx1112.90Eng No 336043 >; See Technical News 114
6T1277777T3 BUSH GEARx155.80
7T1270821T3 GEAR DAMPER 48T Hx1211.30
8T1271992T3 WASHER TORSIONAL DAx118.40
9T1270840T3 FOLLOWER TORSIONALx1129.60
10T1270888T3 SPRING TORSIONAL DAx127.20
11T1270815T3 SHAFT DAMPER THREAx1397.50
12T3990192T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Silver Covers; See Technical News 114
12T3990193T3 KIT TORSIONAL DAMPEx1112.90> Eng No 336042 - Black Covers; See Technical News 114
12T3990191T3 KIT TORSIONAL DAMPEx1112.90Eng No 336043; See Technical News 114
13T1270886T3 WASHER SPRING DISCx13.50
14T1271111T3 NUT SEAL OUTPUT Mx121.10
15T1270600T3 SHAFT/UNIVERSAL JOINx1646.50Rocket III & Classic
15T1270700T3 SHAFT/UNIVERSAL JOINx1646.50Roadster Only
16T1270500T3 SPRING DRIVE SHAFTx16.30
18T3600068T3 SEAL OIL 40 62 6x114.90
19T1260184T3 GASKET OUTPUT SHAFTx122.30
21T1260222T3 BEARING RETAINER PLAx19.80
I wasn't believing the new old stock figured low mileage. In gearing helucal gears are usually sold mas a matched pair. Not that you would have to. I've sent just the one helical in a complete torsional damper assembly to be a parts donor. Anyway sorry to make you hunt down all the info.
All part of the fun of learning:thumbsup::cool:
