jthree
Turbocharged
Ontario, Canada
2007 Rocket III Classic
I was reading a thread about high idling and replacement a TPS but now, for the life of me, I can't find it. I thought I posted this question but maybe I'm dreaming.
My question is, the TPS in question is the primary TPS? and if so, what is the part number I should be looking for.
Thanks
Jthree
Thanks Skip
Is there a "how to" anywhere on replacing it? is it much of a job?
Is BikeBandit the only place to order?
Is this it?
Cheers
Jthree
Now that's funny. I actually wondered if I was passing my limit for questions within one post:)
Does protocol dictate I post separate posts with one question per post?
That said, you didn't answer one of them.:)
The picture you posted shows the secondary TPS, the primary TPS is on the right side of the throttle body looking from the side. You will need TuneBoy or Tune ECU to fit and calibrate The TPS to operating tolerance settings. If you dont want to do it yourself the triumph tech can do it for you.
