Mike Rocket
Rocket 3
Does anyone lubricate engine and case bolts with an anti seize grease when refitting them after removal and if so what would you use? Copper slip or alumslip (by Molyslip) anti seize compound?
Is there a problem with galvanic corrosion when using copper slip on steel bolts threaded in alloy?
The question is: Do I use Copper slip, Alumslip or nothing when refitting bolts into the aluminium engine.
