Test rode a Rocket III standard on Saturday
Play in the risers?!? Then there is something wrong! There shouldn't be play in a riser no matter how tall they are.
I have Rivco's on my R3 and there is no difference in the "play" from the factory risers.
You might want to recheck your torque, sounds like something isn't right.:eek:
Gotta agree with that, I just finished installing the Rivcos on my 08 Standard and they are rock solid, no play whatsoever.
Peter
As a note, Daryl and Crazyman both ride R3Ts. A different part than the riser for the Standard/Classic. Mine moves a bit fore and aft as well.
You can't compare R3T risers with Std and Classic R3 risers. They are very different.
The Std and Classic R3 risers are solid.
I can't comment on the R3T but my guess is that Triumph tried to clone the Road King so much that they even included the wiggle-around handlebars.
Classic pull back bars will fit without the longer cables as I never changed mine. Now that I will be add reversed Rivco risers to the classic pull back bars to make room for a steering dampener I will have to change the cables but hey they are easy to change.
