warp9.9
Pocałuj mnie w dupę
Aha...
So reading this thread...
http://www.r3owners.net/general-tech-talk/11317-high-idle-eratic-tacho-2.html
I could have problems with either the Stepper motor or the TPS.
If i push the Stepper motor back, the revs drop, but as soon as i release it they go back up again.
As with the above thread, if i stop the bike it starts up and is fine for a while then back to 2000+ rpm.
if i take a looksie at the TPS will their be any obvious things to see?
Thanks
Daz
older style tps has blck inards new style has blue. Yours is a 05 so if it has never been changed it will have the od style.
If you do not have tuning aids to set it you should not just pull it off. Tune boy has such ability. If you install a new one the next step would be to sync them by performing a idle stepper motor control voltage reset. before doing this cleant the linkage area with WD40 to insure everything is free moving. From reading your post about moving the stepper motor arm and lowering the rpm until you release it tells me it is not in sync with the TPS and therefore the ECU map either.
If you have tune boy changing the tps and resetting ISCV is a snap as it walks you right thru it step by step on the screen.
As brit man said you can run without a stepper motor I did for over 20,000 miles before I went back to it. With the TTS blower kit pulling it was in the normal instal directions. You would not notice a engine fault as you automatically had one when you eliminated the MAP sensor. I have since corrected the problems keeping one from running these items with the blower. All you have to do is pull the stepper motor and either leave it plugged in and under the tank or unplug it and hide the wire. You then adjust idle via the manual 0% stop set screw and lock nut.
If you eliminate the motor and your TPS is bad you will just experience different problems with fueling accuracy of the map. First worry about the TPS and I bet your stepper motor is still good and working fine.
