warp9.9
Pocałuj mnie w dupę
Could be he shimmed/adjusted the contacts between the motor and the solenoid? As they do get arced up a bit. Let me check and see if I have any pictures on my computer.OP may have meant brushes as I can't think of a single thing on the starter motor that would require shimming - sounds DODGY.
Below is a pick of brush set.
The above is an after photo as I soaked it in vinegar and water for a week.
Below is the before shot (was submerged in water with battery connected)
If you decide to do the starter motor mod looks at these contacts and the ones in the starter and use the best. But I can see and remember the slop in the holes the contacts bolt in and the ability to adjust the contact surface even rotational.
