Starter and headlights not working
Discussion in 'General Tech Talk' started by Oldwarrior, Jul 28, 2018.
Tags:
  1. Oldwarrior
    Oldwarrior 08 Touring
    Country:
    Canada
    75
    Featured Threads:
    6
    23
    8
    West coast, Canada
    Ride:
    08 Rocket iii touring
    bought a few starter relay's last couple of years.
    last week my girl wouln't start very easy. Usually a booster pack will do it but not this time i had to use the car. started it 6 times after the boost thought it was a glitch. A couple hours later needed the booster pack but she started. I metered the battery was over 12v and thought a run might straighten her out.
    Got to the gas station a few clicks some slow turning over then nothing but starter relay clicks. Got towed home :(
    bought a starter relay didn't help. Took the battery in got it load tested. still nothing checked the fuse for the 3rd time.
    rebuilt the starter by professionals. again nothing
    cleaned all the power and ground connections. nothing check fuses again
    neutral light is on so I checked the clutch switch looks good.
    tried her stand up and down. nothing
    put the tuneecu on her no green light for the starter switch. It was a little dirty but not bad cleaned it good using sand paper and wd40 tested it for resistance 0.0. not sure i tester the power in put it showed 0.04???
    check the both relays all good clicking and 0.0 resistance.
    Did these test i found on here;
    You really need to break out your meter and follow the signal path (all voltages per red probe with black on battery negative)
    1. Do you get 12V at both sides of Fuse 9? passed
    2. Do you get 12V at the starter/headlight relay, on the Blue/Yellow wire? Failed
    3. Do you get 12V at the starter/headlight relay White/Red wire when you press the start button? passed
    (clutch not required for this test) Connect Red probe to battery positive, test with black probe:
    4. Do you get 12V at the starter/headlight relay yellow/brown wire when you pull the clutch lever? Passed with or with out the clutch being pressed
    On the wiring diagram blue/yellow wire goes straight to the fuse #9???
    I have switched the ECU relay with the others no change. might buy 1-3 anyways just in case.
    I have bought a few voltage regulators but that issue seems fixed...
  2. DEcosse
    DEcosse If it's no Scottish it's CRAP!
    1,835
    Featured Threads:
    25
    Media:
    19
    2,546
    323
    Bay Area, CA
    Ride:
    Triumph Daytona (Custom)
    If you don't have 12v at the blue/yellow either fuse is bad or your key-switch is bad
    Since you have touring take a look at the actual key-switch connector and inspect the terminals for burning
    But that doesn't compute that you have 12V at Fuse 9 (one end of which is the Blue/Yellow wire that goes to the Starter Relay)
    Are you sure you have 12V on BOTH sides of the Fuse?
    Leave Fuse in place - take your meter and connect black to the battery negative; take the red probe and touch it to the exposed metal tabs on top of the fuse - check both sides.
    Jag, Fingers, rng3 and 1 other person like this.
  3. Oldwarrior
    Country:
    Canada
    75
    Featured Threads:
    6
    23
    8
    West coast, Canada
    Ride:
    Thanks I doubled checked 12 volts at the fuse 0 volts at the switch. Ran a wire from the positive to the switch and it fires up nicely now, better than it has in a long time. :)
  4. Oldwarrior
    Country:
    Canada
    75
    Featured Threads:
    6
    23
    8
    West coast, Canada
    Ride:
    again in over my head..
    I have 2 starter relay switches both will start the bike.
    one I just bought stays on all the time even with the key is out.
    The other one makes the headlight come on while starting but goes out when it is running.
    Is it how I rewired the blue/yellow wire or is it that relays are just crappy and I need to buy another one???
  5. Mittzy
    Mittzy The Hooligan - Just Doing Stuff
    8,331
    Featured Threads:
    84
    Media:
    19
    7,678
    823
    Brisbane, Australia
    Ride:
    2010 R3 Roadster (Matt Black) Called BRUTUS
    Check the plug for the Illes switch as it has been known to burn out but rarely
  6. Oldwarrior
    Country:
    Canada
    75
    Featured Threads:
    6
    23
    8
    West coast, Canada
    Ride:
    Illes switch? not sure what or where that is.
  7. Ygransom
    Ygransom Turbocharged
    Country:
    United States
    668
    Featured Threads:
    1
    Media:
    10
    684
    103
    Surprise, AZ
    Ride:
    08R3T
    Relays come in normally open or normally closed versions. Sounds like you have the wrong one
  8. TURBO200R4
    TURBO200R4 stand up straight and grab the world by the a$$
    Country:
    United States
    4,846
    Featured Threads:
    7
    4,034
    823
    TUCSON AZ
    Ride:
    07 rocket III classic
    may be kill switch
  9. TURBO200R4
    Country:
    United States
    4,846
    Featured Threads:
    7
    4,034
    823
    TUCSON AZ
    Ride:
    the relays them self's r basically the same
    it is the way they r wired in the vehicle that changes the way they work
    my 2007 was wired so when u turned on ign power would enter the relay and go to the headlights(the normally closed circuit) when u hit the starter button if all your safety's (neutral ect) it would activate the relay (closed) sending power to the starter solenoid.
  10. TURBO200R4
    Country:
    United States
    4,846
    Featured Threads:
    7
    4,034
    823
    TUCSON AZ
    Ride:
    sounds to me like u may have a bad ign switch
    i think u may have wired a positive wire in between the ign switch and the starter switch
    i do not have a good wiring diagram of the touring
    but if it was mine i would be checking at the starter relay.
    85 & 86 is the coil that energizes the relay
    the power comes in on 30 so with it unpluged u should power if ign switch and fuse r good.
    if u have a good power on 30 (relay out of connector) u can jumper #30 to 87 (make sure u r in neutral)
    because it will crank over and probably start.
    keep in mine that the diagram on the relay is going to be reversed when u look into connector.
    i checked a couple of relays and the coil circuit is 70 to 90 ohms.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
