Spot of trouble with clutch
Wrecka
Pimpama
2013 R3R
Hey all,
have installed Rivco RIsers , when i was routing cables i had trouble undoing the clutch cable , so silly me undid and removed the lower clutch cable lever off the splined shaft coming out from the engine , went to put it back together but now theres way to much slack in the cable , question is
: do i have to preload the clutch ?
: if so at what position do i need to place the lever on to start the preload ?
Sure one of the more technical Members can post a pic of where the arm should sit on the shaft. That's the problem .. where arm should sit on shaft to give you right amount of cable length .. yeh?
here ya go mate hope it helps
Yeah mate thats what im looking for , rmembering it's a 2013 R3R , cheers
