owl
Turbocharged
Recently on this forum I've seen posts about this problem. Haven't got it myself, so I don't know whether this will be any use, but a question in this weeks Motorcycle News seemed to cover the problem. Reproduced in full :-
QUESTION : I've read in MCN that a fair few Triumph owners have got problems with their brakes; I've got a 2005 Triumph Sprint ST with spongy brakes and way too much travel at the lever as well. Is there a fix out there yet?
ANSWER : The problem is the brake pistons. The earlier bikes have a shiny metallic surface and they may have been assembled dry by the brake manufacturer. This makes the seals drag the pistons too far back off the pads, giving excessive travel.
The brake pistons now fitted in the Speed Triple have a special black coating thats less susceptible, but the major fix is to remove the calipers and pads and carefully lubricate the caliper pistons with brake grease. As long as the rest of the system is up to scratch it should totally transform the performance.
