speedometer inop
Bigfoot
.060 Over
Felton De.
2006 Rocket Classic, 2007 Rocket
After going up to NJ in alot of rain When I started the bike back up to come home the speedometer did not work. Have not gotten a chance to check things out yet. The tach worked and all lights but the odometer did not work either. Upon start up sequence the speedometer needle rotated as normal but would not work while driving. any ideas or suggestions?
Thanks in advance
Check fuses first. If all are good, disconnect your battery for 60 seconds.
If it still behaves the same way, check your VSS wires. You can find where they are in the manual.
