I found an eBay listing for the water temp joint pipe that said 22mm was compatible with the Rocket. So I've ordered one of those. Should arrive in a couple of days. In the meantime, I'm working on the harness.
I've cut the ends off the instrument cluster harness so i can utilise the stock instrument multipin plugs and labelled all the wires to make soldering it together easier. I'm not using 4 of the stock wires (alarm -, alarm +, coolant temp, low fuel) so I've removed them. Also cut most of the connectors off the Acewell gauge as they were huge and would not fit well.
The length of the wires coming out of the gauge means they would only just have fitted inside the frame behind the headstock. I figured it'd be neater if I just soldered them together and heatshrunk it all. The small 2 pin connector still on the gauge is for ambient air temp. The sensor comes pre fitted with the male connector so it made sense to leave that in place.
I will also probably fit the 1Mohm resistor on the tach signal as well as running a wire from the fuel level sender to this gauge. That will mean disconnecting it from the ECU but I doubt that will cause any issues. I think the only thing the ECU would do with that signal is turn the fuel light on and off and I'm not using that.
Hopefully it won't cause error codes. If it does, I guess I'll just fit a resistor from Gnd to the ECU wire so it thinks it's measuring the fuel level.
I'll also have to run switched +12V to the road speed sensor as the old speedo used to do that.
The dodgy aluminium bracket mounts to the same part of the triple tree as the stock gauges. I have this one offset to the right so I can mount my GPS to the left of it and they both fit behind the screen. I'll clean the bracket up later once I have it all working. I'll round off some edges so it doesn't look so square and paint it black.
Once the GPS is beside it and the screen is in front of it, you'll hardly see the bracket anyway.
