As Sidecar mentioned, i had to repair my shifter internally due to a missed curve and a downhill slide
. The cases must be split in order to do any type of linkage, shift pawl or transmission repair itself. There are certain types of special tools you MUST have in order to disassemble the cases. The repair itself to the shifter takes ten minutes. Getting to it takes two days As the bike must be totaly stripped down and the frame removed from the engine! No, that is not a typo....you basicaly sit the engine on the ground after removing the the wheels, and unbolt the frame from the engine and lift it off! Bigern
