Love it when videos are posted! When I saw this and then read the manual, it made me nervous since its opposite to what the manual says. For a fact the sensor won't go on without removing the entire throttle cable brackets from the body. If you follow the video, then you can install it and get full manual range on the throttle plates. However, I can't reach the 0.6 volt setup with the sensor fully pushed toward the engine. I can reach 0,8 volts. When I manually close the plates, turn the key on, the plates open just a little bit. Using tuneboy, I ran a test on the secondary and it opened fully. Maybe I could file the slot in the sensor a bit and get there, but I'll give it a ride first. Maybe it doesn't matter but I am certainly no expert.
