rpm gage electric prob
lightyear
when turning the ignition switch on the rpm gage lights blink once and thats about it, the dial is not making the full jump to max and back...so after this first blink the gage is pretty much ded...help
Pull it off the bike, disconnect the electrical plug, put a little diaelectric grease on it and plug it back in.
speedo works fine...now the bike wont start at all, when turing the ignition key the lights go on speedo is doing the usual jump from max to 0 the rpm gage only blinks once there is a ticking noise from the front (like a little grind noise ) and the bike does not respont to the startup botton
Did you reolcate your ignition? If you did you might want to pop the back of it off and check the solder connections.
it was a loose conection under the gas tank, everything is working fine now...thanks guys
