Dawg68
Nitrous
dawg68
i agree that all current passes through the ignition switch. and i believe that the head light current is what causes the ignition switch to go bad because of the first initial contact spark inside the ignition switch each time you turn on the switch keeps deteriorating the switch until the contacts can no longer carry the electrical load. that is why you need to remove the headlight current from the ignition switch.
however it does make a difference in what order you turn on the kill switch or ign. switch.
if you turn on the ign. switch first with the kill switch on the electrical contact will be made inside the switch,
if you turn on the ign. switch then the kill switch the electrical contact will be made inside the kill switch.
and the same is true for turning it off.
Kinda...... Like I mentioned earlier, irregardless of your initial starting or stopping sequence, current from the circuit, based on how the manufacturer wired the ignition circuit, will flow through the ignition switch. The current that flows through the switch is all dependant on the load that draws it, like the headlamps for one example. It's the constant current draw through the ignition switch, if excessive, can cause pre mature failure of the switch itself. I think what you are trying to say is that if you leave the kill switch on and turn on your ignition the initial contact between the contact points cause an arc and after a time can burn. This is why you use the kill switch to turn on and off your bike. I understand your logic completely. It's a change in electrical potential that causes the spark and believe it or not, the initial current draw from that spark is very small, not enough to damage anything. If this initial change in potential was large enough, yes the contacts could burn on initial contact, this is not the case. I'm not saying your method of starting or stoping your bike is incorrect, I'm just saying I don't believe it will prevent ignition failure. It's just normal wear and tear on the switch, just like every other ignition switch in the world on what ever vehicle.
When the ignition switch is closed, bike running, the contacts inside the ignition are no different than a piece of wire and just like a piece of wire, it will only handle a certain amount of current to flow through it before it burns up. That said if the current draw causes enough heat it could melt plastic parts in the ignition and cause many problems.
This is why some fellas have installed the beaver in order to reduce the amount of current draw through the ignition switch, this is a good thing. Reduce current flow, reduce heat.
I am in the process of installing a relay controlled fuse block so that I can add whatever accessory I want and it will be in dependant of the rockets wiring harness.
The only theory I have with respect to fellas having ignition problems is that the ignition switches that Triumph used may not be able to handle the amount of current that flows through them. I have the ability to measure the current flow through the switch but I don't know the specs on the switches so I can only speculate.
Back to the original post......is your headlamp working?
Cheers all
